Kubota L275 starter is streaming oil
   / Kubota L275 starter is streaming oil #1
mbmarbach
I have had my L275 for a year, and it always starts, and I haven't had any problems. I went to move it and when it started it was leaking hydraulic oil from the starter, a steady stream of it. I pulled the starter every thing looks ok, I took the tractor out to check the clutch, and forward and reverse gears. Everything works fine. 3pt is also working fine. When running, the sight glass is full of oil, when I shut it off it is in the safe level area. The tractor set for 3 or 4 weeks without running, but it has set for longer periods without any problems. I can find nothing in my owners about this problem.
Selco V5-HD Vertical Hydraulic Baler (A51691)
Selco V5-HD...
2020 Bobcat S850 Skidloader (RIDE AND DRIVE) (A50774)
2020 Bobcat S850...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2018 Maserati Ghibli Sedan (A50324)
2018 Maserati...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
