Alpha Dog
Last week, I was trying to figure out how to install the Kubota supplied ROPS on the old Kubota L275 we bought so the spouse would have her own tractor. Well, after searching the ENTIRE internet, I found a set of instructions for installing the ROPS. Drove tractor up on driveway and got it installed this Tuesday, then, the tractor wouldn't start. It was running fine when I drove it there, oil, water, etc. were all okay, no strange vibrations or noises.
After installing ROPS, no lights, no lights on the dashboard, not a click, whir, or buzz.
Checked battery, it's okay. 12 + volts, amps okay.
Checked fuses, all okay. Replaced inline fuse holder for hazard lights, in case that was related to dash lights, and it was kind of 電ry rotted but no change.
I disconnected everything electrical that leads to the rear of the tractor, to cut out any "short circuit" I might have caused by pinching any wires while installing ROPS. No luck, no change.
I seem to have power at the big lead to the solenoid, and still have power at the center lead to the key switch, and to the glow plug wires from the switch.
Used multi-tester to test clutch safety switch, it seems okay, shows continuity when clutch is depressed, (and I figured that with having no dashboard lights, for oil pressure,charging system, etc. it wouldn't be a safety switch issue anyway.)
Took starter off engine, it turns, at least by hand. Solenoid doesn't even click when I turn key, but I still don't seem to be getting power all the way there anyway.
I used the FEL on the other tractor to "hoist" the ROPS into place to install it, but no big "bumps" or vibrations that I thought could have damaged anything.
What am I missing? I thought about the switch itself, but no one locally has one in stock, so it値l be a week or so before I can get one, and since I致e got to work next weekend, longer than that to get it installed.
Any input or suggestions would be appreiciated.
