Kubota L2500
   / Kubota L2500 #1
Whistlepigman
Kubota L2500
Clutch does not engage when pedal is released. Pedal does not fully return. Can pull it back with my foot and it wiil engage. Any Ideas?
   / Kubota L2500
External spring is still attached
   / Kubota L2500 #3
You could start by playing with the adjustment. You should have about an inch of pedal travel before meeting some resistance of the clutch disengaging.
   / Kubota L2500 #4
Does your tractor sit alot between use? Is it exposed to weather?
I one the same machine. I would spray some PB blaster on the pivot points and rods that are outside of the case.
Adjustment would be next.
If I recall correctly there is an access door to the clutch on the clutch pedal side of the tractor. You can remove it and see the clutch assembly.
I suspset that your throwout bearing is possibly sticking. Not siding as it should. Look for a grease fitting on the bearing. I read long ago that some of them had one and some did not. But that would only grease the bearing itself. Not the contact area of the inner race to the transmission shaft.
Either way you should be able to shin a light in there and see whatbis causing it to hang up.
   / Kubota L2500
Thanks for all the advise . Clutch area rusty as heck. Bit the bullet and had a clutch job gone and full service fluid change
2018 Chevrolet Tahoe 4x4 SUV (A50324)
2018 Chevrolet...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
Lincoln Electric Vantage 300 Welder/Generator (A49461)
Lincoln Electric...
2020 JLG Telehandler (A49461)
2020 JLG...
2017 VOLVO VNM DAY CAB (A51222)
2017 VOLVO VNM DAY...
2005 Big Tex 10PI 16ft. T/A Utility Trailer (A49461)
2005 Big Tex 10PI...
