KUBOTA L245DT
   / KUBOTA L245DT #1
Arbo
Bronze Member
I found another used Kubota locally. Will the L245DT with a factory loader handle moving and stacking round bales? Thanks!
   / KUBOTA L245DT #3
First Kubota I ever owned was a 1979 L245DT. It did not have a loader but it had a heavy duty dozer blade -- amazing what it would do. It's a very rugged and dependable machine but it may be a little light for handling large round bales. A 35 - 40 HP tractor would work much better.
   / KUBOTA L245DT #4
With a rear 3-point hitch spear, a L245 would move round bales. But it's too small to lift that much weight high enough for stacking with the FEL. With enough balast it might actually do it, if on a dead level smooth paved surface - but it would be beyond its stable limits. As a general guide, a tractor should weigh roughly 4 times as much as whatever you routinely handle with the FEL. Everybody exceeds that now and then, but it gives you a general picture that the L245 is maybe 35% undersized for round bales.
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2013 Ford F-150 Ext. Cab Pickup Truck (A50323)
2013 Ford F-150...
2013 MACK GU813 GRANITE ROLL OFF TRUCK (A50854)
2013 MACK GU813...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
1968 International Harvester 856D 2WD Tractor (A50657)
1968 International...
2014 PJ 24+6 T/A GOOSENECK (A50854)
2014 PJ 24+6 T/A...
