Kubota L245DT low-high range lever
   / Kubota L245DT low-high range lever #1
foxwood14
Kubota L245DT
I broke the selector lever for the low-high range. I pulled the pin that holds the lever on but it still does not want to come off. Do any of you know about removing the lever?
   / Kubota L245DT low-high range lever #2
I just finished taking my 245dt apart to replace a pto shaft seal. Very labor intensive. Your high low adustment is not as you would think. It goes through the case and another rod is welded onto the horizintal shaft and collar that you see on the outside of case. My lever was broken off about 10 years ago and was replaced with a small pair of vice grips. Little did I know that they would be on there for ten years. After removing the top of the tractor as well as splitting the tractor today- the high /low was repaired by mig welding a rod and ball where the original broke off. I would suggest you do the same...
Thank you for the information. When I couldn't get the collar off the shaft I was puzzled why it had a pin through it. I still don't understand what purpose the pin serves if it doesn't hold the lever and collar on the shaft.
1994 Mack CH613 Day Cab Truck Tractor (A49461)
1994 Mack CH613...
2019 CATERPILLAR D6 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2012 MACK GU713 DUMP TRUCK (A50459)
2012 MACK GU713...
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
2018 Allmand Light tower (A49461)
2018 Allmand Light...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
