drmaster said:Thanks for the information. I'll try and answer some of the questions to see if it will narrow the scope of my investigation. The engine is a Kubota DH1101-A, 3 cylinder, vertical, water cooled 4 cycle engine, without a turbo, rated at 25 horse power. The engine appears to run as well as it ever has with little visible smoke of any color. There is black oil or diesel leaking between where the exhaust manifold attaches to the engine block on only the front cylinder. Additional oil, or diesel, can be seen leaking through small holes where the 3 sections of the manifold come together going up the stack.
Any additional advice would be greatly appreciated!
DieselPower said:If it's oil and it is a turbo charged engine DO NOT RUN IT ANYMORE! If it is the seal within the turbo you could be pumping engine oil from your turbo into the engine. A running diesel engine can "run away" when the turbo oil seal goes. Even if you shut the engine off it will continue to run on the engine oil and the RPM's will continue to increase until it blow's up. Seen it happen more times than I can count on my fingers. To check for this, remove the turbo clean air side/preasure out line and see if there is any oil in it. If there is even a trace amount of oil in the preasurized air side the seal is gone. Get the turbo rebuilt.
