Kubota L245DT 4wd
   / Kubota L245DT 4wd #1
Jerome
Elmvale Ontario Canada
Kubota L245dt
Hello all
I just had a bad morning trying to blow snow, we have about 4 inches of dry over wet snow. I lights quit working and my tractor does not seem to want to go into 4wd.
The lever is back like it is supose to be but the back tires were spinning but not the front any ideas on what to look for to see if they are engaged? or how to trouble shoot the 4wd system?
   / Kubota L245DT 4wd #2
wow sorry for the bad luck
well as far as i know (l245dt owner)the wires and 4wd have nothing to do with each other.
are you sure the levers are in the places they should be?
i mean forward and revers lever was well as the 4wd lever ?i have a book this the part numbers if you need them.
   / Kubota L245DT 4wd
Sorry I guess I need to be more clear I know the wiring has nothing to do with the 4wd it just happened to go at the same time I think it it the switch.
Yes I checked my Manuel and the levers are in the right places.
   / Kubota L245DT 4wd
Well it got loaded onto a flat bed for the trip to the dealer. my pocket book is already hurting.
   / Kubota L245DT 4wd #5
well any word as too what they might have found?
   / Kubota L245DT 4wd
It was a "split ring" that broke off inside. They had to drain the case etc. to fix it still waiting for the bill but at least I have my tractor back for the next round of snow squalls.
   / Kubota L245DT 4wd
250 in labor
150 to pick up and deliver. this seem a bit excessive as I had to rescue the driver after he drained my battery trying to start the tractor.
2007 International 4300 DT466 Refer Truck (A47384)
2007 International...
2022 CATERPILLAR 299D3 XPS SKID STEER (A51242)
2022 CATERPILLAR...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2007 Ford F-150 Pickup Truck (A50323)
2007 Ford F-150...
2014 FORD F-350 SUPER DUTY CREW CAB FLATBED TRUCK (A51243)
2014 FORD F-350...
John Deere 7130 Loader Tractor (A50514)
John Deere 7130...
