Kubota L245 lift arm linkage.
   / Kubota L245 lift arm linkage. #1
BobbyH
I have a Kubota L245 two wheel drive tractor that does everything I ask it to... except for one problem. I have been trying to get a subsoiler to dig in and actually make a cut, but the lift arms won't go lower than 15 inches off the ground. The right arm linkage is adjustable, but the left arm linkage is not. Why is that? How long should the left lifting arm linkage (Stabilizer?) be?
Mine is about 15 1/2 inches, but it looks like it needs linkages that would be 18 inches in order to get the lift arms down to about 4 inches off the ground. Anybody know how long the left linkage should be?
I replaced the fixed one with a spare top link I had laying around, and with both linkages extended out to 18 inches, I got the correct deployment of the subsoiler, and it dug into the ground as it is supposed to. But why would Kubota make a tractor linkage that is not adjustable? Strange....
I will really appreciate an answer to this. I'm stumped.
   / Kubota L245 lift arm linkage. #2
The older Kubota 3-point linkages have a crank-adjustable lift rod on one side. The other side's lift rod is forked and has two sets of holes about 2" apart for the lower pin. In the lower position, the arms reach down to about 3" off the floor. If your lift rod doesn't have extra holes, it may have been altered or replaced. It should be possible to match the length of the cranked side. You could solve it by adding a bolted extension or by ordering a new original lift rod (I have L175, L225, L295 and L345 parts lists - but I don't know which if any is right for your L245)
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A53472)
2015 Ottawa Yard...
2021 Vermeer Wood Chipper (A51573)
2021 Vermeer Wood...
2012 Chevrolet Silverado 2500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
2020 Steiner 450 Slope Mower (A51573)
2020 Steiner 450...
Miller and Smith PNR-1000 Pull-Behind Proof Roller Trailer (A52377)
Miller and Smith...
Billy Goat Blower Paint Dryer, 6.5 Briggs (A52384)
Billy Goat Blower...
