Hey there all.
I just picked up a Kubota L245 2WD with a Bush Hog 1846QT FEL. I need to change the hydraulic Trans Fluid, but not sure where to put the fluid in or how to know when it's full. There is an adapter where the filler cap is, that the hydraulic return hose is connected to. Is there another place to add the fluid? When pulling the filter screen out, does that drain out all the fluid, or is there a plug on the underside as well? I've also noticed that several Kubota models also have a drain plug on each gear box for the rear wheels. I don't see a plug there, but wanted to double check.
Thanks,
Monty
Thanks,
Monty
