Kubota L245 3 point lift
   / Kubota L245 3 point lift #1
estodd
Well, well, well,
That #@%&## Kubota l245 hydraulic lift is still giving me a fit.
I had posted previously and gotten a few responses and tried everything to fix it but still having problems.
Here is a quik run down on what happend.
Bought tractor 3 or 4 weeks ago. 3 point lift was not working. I cleaned the filter screen. The lift worked great for a few days.
It was working one morning and I backed up to a pile of dirt, lowered the box blade and that was it. The lift will not work.
I had a mechanic pick up tractor and take it to his shop.
He rebuilt the hydraulic cylinder.
The lift worked great and would lift a battleship!!
It worked for one day even though the pump was only putting out 25 psi.
The next day it was not working.
It will only lift at full throttle with no load on it. If you rest your foot on the lift arms it will not lift. That is the same thing it was doing before the mechanic rebuilt the cylinder.
It will not go down by itself. I have to push it down with my hand.
I put a new pump on it this afternoon and still no lift.
The mechanic came by and checked the relief valve and it is not stuck.
Any ideas guys?
Thanks to all
   / Kubota L245 3 point lift #2
On mine I have to sometimes turn the knob several turns until it lifts. Have you changed the hydraulic oil? Check to make sure the filter is properly seated. At one point I also discovered that mine wasn't seated properly, allowing unfiltered oil through the system. Perhaps you have some debris floating around in there. Doug
Thanks for your reply peteguod
I have changed the fluid , cleaned the filter 4 times.
the mechanic who rebuilt the hydraulic cylinder took the inspection plate off the bottom of transmission, cleaned everything out. No gunk left in there.
I cleaned out the vent tube which was plugged up. The relief valve is good.
I am at a total loss here.
If anyone out there has any ideas please please respond.
2023 CATERPILLAR 299D3 SKID STEER (A51246)
2023 CATERPILLAR...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A52377)
2019 Generac...
30 Yard Roll Off Container (A51573)
30 Yard Roll Off...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
2019 JOHN DEERE 5090M LOT NUMBER 91 (A53084)
2019 JOHN DEERE...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A53472)
2016 KBH...
