Front-End Loader Kubota L2350dt w/LB400 loader, where do the support arms mount?
   / Kubota L2350dt w/LB400 loader, where do the support arms mount? #1
TaterK
las vegas, nevada
kubota l2350dt w/lb400 loader
where do the support arms mount? I just acquired this tractor and it has a few problems! first I need to remove the LB400 loader, the 2 bolts in front have been removed, as well as the lower bolt on each side or rear tower.
Problem control valve for bucket dump not responding, cant tip bucket forward.....front tries to come up but the rear posts don't seem to move. This loader does not have the slide out lock pins.
Thanks for any help!
TaterK
   / Kubota L2350dt w/LB400 loader, where do the support arms mount? #2
By lower bolt, you removed the very bottom "bolt" on each side that's keyed, correct?
Did you install the two stands which are located directly in front of the steering wheel, connecting the two loader towers, to the bucket?
If the control valve is busted, you can remove the loader pretty easily by using some heavy straps connected to something overhead and sturdy. I have a L3650 with a LA650 loader which is the EXACT same design... the kick stands were not wide enough for my turf tires, and the bucket and stands were not enough to lift the loader out of the sockets, so I strapped it to an overhead beam in my barn and it easily lifted off that route.
2006 Volvo VNL (A52128)
2006 Volvo VNL...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2018 Ford F-150...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
Little Giant Poly Water Tank (A50515)
Little Giant Poly...
7' Snow Blade (A50515)
