My Kubota L2350 lost all power steering @500 hrs. Turned it back and forth while going slow and regained some power. Tried turning all the way both ways to bleed any air and shutting off as per service manual. No better.
Seemed as though power steering was getting no hydraulics at all so I removed the priority valve to inspect for stuck spring. Nothing wrong.
Now I assume I either have a bad (weak) hydraulic pump or something wrong in the steering mechanism. Have not inspected the transmission filter or replaced the trans oil. The power steering runs off one hydraulic pump with a priority valve that prioritizes the flow to the power steering before going to the [front loader]. Front loader works as if nothing is wrong.
Note. I think an after factory block was added (@ 40 hrs) to the priority valve to better direct the flow of hydraulics to the front loader.
I live on an island so fixing it myself is a priority.
Any help appreciated.
