Kubota L225..anyone know anything about this?
   / Kubota L225..anyone know anything about this? #1
theelves
We are wanting to go look at a Kubota L225, 4wd, 1090 hours, 3 cylinders, 25HP for $3995. But were wanting to know if any of you out there have any knowledge/expereince with this kind of tractor? Is it easy to get parts for? Does it have a good/bad rep for holding up to hard work? We are told it is"clean". good tires, a bit faded paint. The previous owner had it for 12 years with a brush hog attatched. Any idea how old this tractor is? Thank you so much for your time to reply, it will really help us out!! /forums/images/graemlins/grin.gif
   / Kubota L225..anyone know anything about this? #2
L225's were produced form '76-'85. If you had a serial # I could tell you the year. They are a very good, solid little tractor. Pretty basic features. THe hours are low and the price sounds good if the facts are correct. Parts are not a problem to get, but you probably won't need any anyway. Good Luck! Christa
   / Kubota L225..anyone know anything about this? #3
In those years the model number corresponded to the gross horsepower - so it's probably 22.5hp - which would mean about 19hp available at the pto.
They are durable units - the mechanicals hold up great, even with hard use. They rarely develop leaks. Unlike some other brands, the basic hydraulic and fuel tubing is properly manufactured, so doesn't rattle apart. Kubota's build quality was very high in those years - they were trying to penetrate the US market and their quality is what pushed the door open. The paint does not resist sunlight too well, but they put it on over properly cleaned surfaces so rust from behind is not an issue. The upholstery and tires may look bad but the engine and transmission are probably near perfect with so few hours.
I'm pretty sure these have a 2-stage clutch. There is an easy check for main clutch wear. With the tractor off, engage the pto lever and have a helper push the clutch pedal all the way down. Then try to turn the rear pto shaft by hand. If you can, fine. But if you can't, the pto clutch isn't releasing and the main clutch may need replacing. (the next level of testing would be with an attachment hooked to the pto - see if the pto clutch can be disengaged).
Some of the small external levers on these models have cracked welds that eventually break. If you see evidence of weld repairs on a lever it's probably just normal.
Hope this helps. Take care, Dick B
2014 KENWORTH T800 (A45046)
2014 KENWORTH T800...
Zero Turn Mower (A44572)
Zero Turn Mower...
2004 Dodge Ram 3500 4x4 Crew Cab Pickup Truck (A42744)
2004 Dodge Ram...
2014 KENWORTH T680 (A45046)
2014 KENWORTH T680...
JCB 509-42 Telehandler (A42203)
JCB 509-42...
New/Unused 20ft x 30ft x 12ft Storage Shelter (A44391)
New/Unused 20ft x...
