Kubota L210 and ULSD
   / Kubota L210 and ULSD #1
crj567
I am worried about this new Ultra Low Sulfur Diesel fuel huring my injectors. My tractor is pretty old, but still runs great, and I would like to be as kind as possible to it.
Anyone use and fuel additives to help out with this ultra-low-sulfur junk?
   / Kubota L210 and ULSD #2
I use some Power Service in mine during the summer and Howes during the winter. They both say they help lubricate every thing.
   / Kubota L210 and ULSD #3
Anyone use any fuel additives to help out with this ultra-low-sulfur junk?
Then don't run it .
Use the RED non taxed stuff instead
I put a quart of power service in the 55 gallon drum when i get it filled.
Is the red stuff higher sulfur? I have been using that, but I figured that the sulfur content would be the same....
   / Kubota L210 and ULSD #5
That may depend on the area you are in .
I feel they are steering away from the high sulfur stuff toward the Ultra Low Sulfur Diesel and one day it wil all be the same .
Once the current stock pile depleats that will be the end of higher sulfur stuff and ULSD will be used both on and off road
2010 Ford F-250 Ext. Cab Pickup Truck (A48081)
2010 Ford F-250...
2005 Ford F-350 4x4 Crew Cab 8ft. Mason Dump Truck (A48081)
2005 Ford F-350...
2016 John Deere TS Gator 4x4 Utility Cart (A49346)
2016 John Deere TS...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
2005 Case IH 2062 Flex Draper Header (A50657)
2005 Case IH 2062...
197390 (A50459)
197390 (A50459)
