Kubota L185DT
   / Kubota L185DT #1
farmyid
Bronze Member
Western Mass at 1500 feet elavation
Century 3040
Hi Folks,
Someone in my area has an L185DT with a loader for sale for $6,500. I can't find the specifications for that machine as they haven't made it in some time, but I beleive it is an 18 diesel 4WD. He says it has 375 hours on it, which seems pretty low for an older tractor. Anyone know where I can get the skinny on the weight, size and other features of this tractor? I was hoping to bee able to buy a larger horse power machine, like the B7500 or b7800., but maybe the extra weight on this c series make up for some of that? sure is a lot less money and I need to buy a bunch of attachments still. Thanks !
Mark L.
   / Kubota L185DT #2
Mark, you can go to http://www.tractortips.com and look it up there. I know nothing about the accuracy of their data, but they show that model to be made 1977-1982, 12.5 PTO hp, and 17 engine hp. 6.00-14 front tires, 9.5-24 rear tires, 8 speed forward, 2 reverse, 2 cylinder diesel. Weight not given.
   / Kubota L185DT #4
I run my 4' brush hog with my 15 hp Mitsubishi with no problem . Don't let that be your only reason for not buying . (15 engine hp/13 pto hp)
   / Kubota L185DT #5
"Don't let that be your only reason for not buying . (15 engine hp/13 pto hp) "
That's right...I'm running a 60 inch cutter through pretty thick brush hooked to a tractor 4 HP under the (rotary cutter) minimum requirements without too much trouble. Just go a bit slower...it'll work OK.
   / Kubota L185DT #6
Mark, I agree with the other guys. I'm not familiar with the L185 but I used a 4' Bush Hog Squealer behind a B7100 that was 16 engine and 13 PTO hp and it was quite adequate for my uses.
   / Kubota L185DT #7
mark the used tractor price guide list the price of the l185dt from $2,930 for a premium cond 1978 to $3600 for a premium 1982...it list pto hp as 15.45 w/a approx shipping wt. as 1785lbs..purchace price new (retail) ranges from $4940-$6290 depending on year....as a side bar i run a woods 48"brush hog behind my b2100 which is rated at 16hp at the pto w/ no problem...hope this helps...george....
   / Kubota L185DT #8
I have an old 10-page Kubota L185 sales brochure. I have no idea how old the brochure is as I received several brochures in 1997? with the purchase of my first used Kubota (B7100D).
The brochure only shows a 2wd L185 and makes no mention of a 4wd option. The models in the brochure are L185FP (farm tires) and L185TP (turf tires). However, the "D" in the "DT" model number suffix you give usually indicates 4wd for Kubota tractors.
The engine and PTO hp values given in the previous posts agree with the sales brochure. It has 8 forward and 2 reverse gears. The weight listed in the brochure for the 2wd L185 is 1628 lbs.
Standard Equipment: 3-speeed rear PTO with one-way clutch and PTO guard. One-speed front PTO shaft. Differential lock. (and more stuff like 12v battery and air cleaner).
Optional Equipment: Power Steering, Draft control, Creep Speed Transmission (I think that this adds a Hi-Low to the transmission for 16 forward and 4 reverse gears).
Hopefully it'll have power steering with the FEL.
Kelvin
   / Kubota L185DT #9
i have a l185dt. this is a 18 hp and is 4 wheel drive. i bought at yard sale with box blade. bush hog (5ft) and it has a grader blade on the front. this is one working little machine. everyone around here has tried to buy it from me. i gave 3000 for it and the equipment.
i am looking for a front loader for this tractor if anyone knows were i might be able to find one. <font color="blue"> </font>
   / Kubota L185DT #10
Been a while, but if anyone is still reading :
I ahve been compiling a list of fron end loaders for the L185 DT as I ham looking ot put one on mine. So far
allied 180 loader (Buehler)???
Buhler 95 w/Q1953 mtg kit - confirmed
Kubota 1200 - requires seperate pump / res (?)
Bushhog 1847QT - cionfirmed
Koyker 80 - (according to Stormer-tractor.com
Westendorf TA-55 - confirmed
ATTENTION! PLEASE READ (A44502)
ATTENTION! PLEASE...
Fleco 30" 8T Excavator Bucket (A42203)
Fleco 30" 8T...
2001 Dodge Ram 2500 Pickup Truck Extended Cab (A44789)
2001 Dodge Ram...
HYDRAULIC SQUEEZE OFF (A45333)
HYDRAULIC SQUEEZE...
New/Unused 20ft x 40ft Container Shelter (A44391)
New/Unused 20ft x...
2014 FORD F-150 (A45046)
2014 FORD F-150...
