Oil & Fuel Kubota l185dt starting problems
   / Kubota l185dt starting problems #1
Pt farmr
Have just bought l185dt with starting problem and would like ideas on the cause. When I start the tractor the throttle needs to be on full to get it going. It cranks a while and when it starts to fire, belches smoke and runs rough till smooths out and then you can throttle down.Also need to shut off fuel when not in use since it will drain itself. Injector pump is wet at the point of fuel line and vent and lower around 4 bolt square plate. Is there o-rings on the vent screw? Is there another problem to look at? Fuel line is new. New to owning a tractor not sure where to start any advice would help. Thanks
Bucket 12 Inch (A50322)
Bucket 12 Inch...
2007 GENIE S-60 4X4 MANLIFT (A50854)
2007 GENIE S-60...
2007 JOHN DEERE 310SJ BACKHOE (A50458)
2007 JOHN DEERE...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR89J160632 (A51572)
2009 International...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
2015 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2015 CATERPILLAR...
