Kubota L185DT Start trouble
   / Kubota L185DT Start trouble #1
Splatmaster527
Ok so I have a Kubota L185DT and it wont start it self. The glow plugs get hot and it cranks and cranks and cranks with white smoke out the exhaust but never actually gets up and goes. We have resorted to pull starting it with our Yukon or our International 244. Once we pull it and get it going it runs VERY strong and the throttle is responsive. It just seems like it doesn't have enough juice to get going. When its cranking it sounds like it wants to run really bad but its almost like its just not cranking fast enough.
Any help would be AMAZING!!
   / Kubota L185DT Start trouble #2
This thing's getting along in years, maybe the starter bushings are worn so the starter draws too much. Or cables or connections are weak, or battery? How much have you checked. Could be compression too, or weak injector pump, but I'd look at the starter circuit first.
Jim
If it was compression or injector pump wouldnt it not run very good once its started?
   / Kubota L185DT Start trouble #4
Are you sure the glo plugs are heating? On my B7100 I crank it till white smoke comes from muffler then heat the glow plugs for about 10 seconds, then crank again. It will always start quickly using this procedure. If the glow plugs did not heat up it would just keep pushing out white smoke and would not start.
   / Kubota L185DT Start trouble #5
Years ago, I had a L245DT (size larger) and had the exact same issue. A new battery fixed it and never had problem again. Apparently the old battery was good enough to crank but not fast enough under load. Try jump starting and if that works then you need a new battery. Also, check all battery connections for good contact.
Electric Scissor Lift (A50322)
Electric Scissor...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
2019 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2019 CATERPILLAR...
2011 Mazda 6 Sedan (A50324)
2011 Mazda 6 Sedan...
2013 Dodge Journey SXT SUV (A50324)
2013 Dodge Journey...
2010 Case 660 Trencher (A50322)
2010 Case 660...
