kubota L1801
   / kubota L1801 #1
rinbond
hi all,anyone got any ideas why the 3pl will not raise when activated although the fel works quiet fine,any help would be grateful,regards
   / kubota L1801 #2
rinbond,
This sounds like either a sheared pin on the handle to control lever or something under the top cover has come loose.
Be sure when you turn the position control lever that the rod it is supposed to rotate does. If no rortation on the rod, then you can replace the pin and it should now work.
Good luck!
2006 Ford Crown Victoria Sedan (A50860)
2006 Ford Crown...
2004 Range Rover HSE SUV (A48082)
2004 Range Rover...
2019 Ford Explorer AWD SUV (A48082)
2019 Ford Explorer...
P&H OMEGA 20-20 (A50854)
P&H OMEGA 20-20...
2008 John Deere 3520 Tractor (A50860)
2008 John Deere...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A48082)
2022 Forest River...
