Kubota L1801 blowing oil from oil filter
   / Kubota L1801 blowing oil from oil filter #1
Mean Jean
Hazelridge, MB
Kubota L1801 and Massey 65
Tractor ran great yesterday and was parked in the garage. Started it this morning and heard a "clunk" which was followed by oil pouring out from behind the oil filter. Fart!
Here's what I've done/found out:
-Removed the oil pan and did NOT find any shrapnel.
-Removed the rocker cover gasket and all is well there.
-Removed the cylinder head and again, no unwanted parts. Put it up on jacks and was able to turn a rear tire while in gear. Pistons are traveling up and down as they should be.
-Removed the oil filter assembly cover and things appear fine. Both the relief assembly valve and safety valve appear to be working fine although I'm tempted to replace them for the $30 it may cost.
-Reinstalled the oil pan along with some oil and turned the motor over. Oil was pumping from one of the ports behind the assembly cover. This leads me to believe the oil pump is in good working order.
-There does not appear to be any liquid where it shouldn't be. IE: fuel mixed with oil, coolant mixed with oil.
-Pick up screen in oil pan was clear of debris.
-Oil filter did NOT have an extra gasket on behind it. No debris found in the oil filter.
So...
What the heck is going on?
I'd venture a guess that a bit of crap got past the filter and forced the relief relief assembly valve/safety valve to fail and forced an oil back up.
Thanks in advance,
Jay D
   / Kubota L1801 blowing oil from oil filter #2
Bolt on a new filter and top off oil and fire it up. Be ready to shut off if oil still pours out. Report results.
Portable Creep Feeder with Gates (A50515)
Portable Creep...
2019 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2019 UTILITY VS2RA...
2025 Swict 60in Bucket Skid Steer Attachment (A50322)
2025 Swict 60in...
2013 AMSIG S/A Solar Towable Message Board (A50322)
2013 AMSIG S/A...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
