Kubota L175 Lift
   / Kubota L175 Lift #1
Old Ford Mechanic
Kubota L175
Power Lift on L175 tractor was working fine.Tractor was parked and sat for a couple of weeks.Lift will no longer work.No action at all on lift arms when lever is activated to raise the lift.Valve is working and you can hear and feel the bypass effect.If you hold it back you can get a squealing sound but,no lift arm action at all.Oil is level with the check plug and is new Kubota oil.Have not cleaned screen across from supply line.Going to do that tomorrow.Does anyone have an ideal what the problem is?
   / Kubota L175 Lift
Ok,I found the problem.The hydraulic system had water in it and the lift piston was seized in the liner.Took a lot of clean up but,i now have it operatioal again.
2020 Toro 6000 Series 60in Zero Turn Commercial Mower (A50322)
2020 Toro 6000...
PT Spiked Roller (A50121)
PT Spiked Roller...
2004 Ford F-250 XL (A50120)
2004 Ford F-250 XL...
Peterbilt 377 Semi-Truck (A52748)
Peterbilt 377...
Set of AG R4 Wheels and Tires (A52748)
Set of AG R4...
KUBOTA M7-132 (A53084)
