Kubota l175 1981 no fuel to injectors
   / Kubota l175 1981 no fuel to injectors #1
Patrickj
1981 kubota l175
I have a 1981 kubota l175 and it isnt starting, here is what ive done. I primed the injector pump with the air relief on the filter houseing and the relief on the injector pump, i removed the fuel lines to the 2 injectors and there is no fuel coming out of the top of the injector pump. If i loosen the two noozles i guess they are atop the injector pump fuel flows but doesnt really pump, if i hook the lines back up fuel will never make it out the other end of the lines so im pretty sure it isnt pumping fuel. The kubota website doesnt sell a pump because they say they are indestructable... what can i do or check to get this thing going. There is also no black smoke coming from the exhaust while cranking thats what led me to a fuel problem. Thanks in advance
500BBL WHEELED FRAC TANK (A52472)
500BBL WHEELED...
2014 Bandit 4000T Foresty Mulcher (A52384)
2014 Bandit 4000T...
SHOULE RM8080 LOT NUMBER 129 (A53084)
SHOULE RM8080 LOT...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2006 MACK CV (GRANITE) BOB TAIL KILL TRUCK (A52472)
2006 MACK CV...
