Kubota L1501 front rim/wheel
   / Kubota L1501 front rim/wheel #1
podieroe
Sale Creek Tn
gravely 5260
I have a Kubota L 1501/L 175 2wd that has a bad front rim (valve stem hole is corroded) , I am having no luck finding a replacement rim, please advise on best repair method. If i weld the valve stem hole, how accurate does the re-drill have to be to accommodate the valve stem?. If there's a rim out there available please advise
   / Kubota L1501 front rim/wheel #2
you can drill a new hole anywhere around the rim that you like. Just be sure that the new hole is somewhere near the same distance from the outer edge of the rim as the old hole. It doesn't need to be perfect as the tube will move around a bit without issue.
2007 Volvo VNL Truck Tractor (A53472)
2007 Volvo VNL...
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
12ft Freedom Chip Body (A51573)
12ft Freedom Chip...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
40ft Pine Straw/Enclosed Trailer (A51572)
40ft Pine...
