Kubota L 4330 want to add rear remote from ft.end loader?
   / Kubota L 4330 want to add rear remote from ft.end loader? #1
wd5mhz
Greenwood,Ar
Kubota L 4340 hst cab
Hello Group i have a question i have a Kubota L 4330 hst C i want to know if i can add a rear remote for a hyd top link. Can i tap in to the front end loader hyd system? were the hyd comes out of the tractor to the front end? what i want to do is get hyd to the rear and use a 2 spool valve and make rear remotes?
The kubota price is way to high for me i want to do something cheaper. do you have any ideas?
Mike Henry
   / Kubota L 4330 want to add rear remote from ft.end loader? #2
If your tractor has a hyd block, you can interrupt the line going back to the 3pt input.
If it is metal lines, you can cut and use compression fittings.
   / Kubota L 4330 want to add rear remote from ft.end loader? #3
There should be a power beyond port on the loader control that is currently plumbed back to the 3-point. Run that to your rear remotes and then run the output from the rear remotes to the 3-point.
   / Kubota L 4330 want to add rear remote from ft.end loader? #4
As the earlier responders have said, you should fine. First, identify the power beyond port (what is going to your 3 pt,) and intercepting the hydraulics there for the basic remote setup.
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
UNUSED Artificial Turf Grass (A53117)
UNUSED Artificial...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2002 Ford E-350 10ft. Box Truck (A55852)
2002 Ford E-350...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2021 Ford F-150...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
