Kubota L 3010 Remote Hydraulics
   / Kubota L 3010 Remote Hydraulics #1
eddieirvine
Indiana
Kubota L 3940
I am a new member and I was not aware that one of your members Madreferee had passed my prayers go out to all the members and family. My question is on hydraulics it has been talked about on here I see many times but I have a Kubota L 3010 and as I have read some time back there was someone who made there own hyd block that connects directly to they ones I allready have under the seat of my tractor, Kubota as of a couple years back and still do as far as I know make a remote hydraulic kit to bolt on to exsisting hyd block. I would like to make this block because they are really proud of theres and I would need a drawing or pictures of this if anyone has them, also how to hook all of this up what I want to do with this is run my top link and and maybe have a spare port for whatever down the road. So if any of you have any suggestions or different way of doing this please let me know I am very open for suggestions thanks Eddie.I.
   / Kubota L 3010 Remote Hydraulics #2
I sort of remember that thread from YEARS ago, when someone machined the block themselves, but I don't remember them posting any detailed specs/measurements about it...Have you found that thread by searching?
Hooking it all up ONCE you have the block is the easy part!
If you could help with the assembly of it all let me know, also I have not really looked into where this block really goes that would be helpfull also thanks again EddieNo I haven't found it with a search I have tried found some talking about the subject but nothing in detail, I am guessing there is someone in the forum with some good information just have to wait I guess and see what develops I just know there has to be a way to do all of this but I want to do it right and not cause any problems with hyd pumps and major parts thanks Eddie
   / Kubota L 3010 Remote Hydraulics #4
Eddie,
I think THIS is the post I was thinking of...There may have been one more somewhere though...
How much is the block from Kubota?
The block is part of a kit which contains the block and hoses if I remember right no valve $700.00 as of last year no Top link hyd cylinder either:(
   / Kubota L 3010 Remote Hydraulics #6
Eddie see if this can help you. I think if you take the plate off under the seat you can get what you need. It looks like to me you well need a valve with PB. If you use a stack valve you can also make the inlet side plate to match your valve. Lee
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A52577)
2012 INTERNATIONAL...
JOHN DEERE 2038R LOT NUMBER 175 (A53084)
JOHN DEERE 2038R...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
New Holland B95 Backhoe (A50490)
New Holland B95...
New Holland LB75B (A51573)
New Holland LB75B...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
