Kubota L 2250 broken shift fork
   / Kubota L 2250 broken shift fork #1
Mike V
Southeast Texas
New Holland TC55DA 4x4
I have a Kubota L 2250 with a broken shift fork. I have pulled the transmission cover and found the front shift fork broken. I have removed two bolts on the outside of the case that I think holds the shaft the forks are on,but it only lets the shaft move maybe 1/8 to 1/4 inch. It looks as if the shaft should move out toward the rear. Is there a trick to remove and replace fork or do I have to split the tractor? Any help would be appreciated.
Thanks,Mike
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2018 FREIGHTLINER...
2016 CHEETAH 40FT CHASSIS TRAILER (A52141)
2016 CHEETAH 40FT...
2017 Ford F-450 XL (A50120)
2017 Ford F-450 XL...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
