Kubota L 1500 oil filter
   / Kubota L 1500 oil filter #1
cartime
South Ga.
L 175 19??
I need the # for a correct oil filter for an L 1500 the # I have been told will fit will not .Mine is a cartridge type,3 7/8" long and 2 1/2" dia.and the hole in the center is 1 3/16. Could anyone please help?
THankx Drew
   / Kubota L 1500 oil filter #2
Hi,
from previous posts, people say that L1500 model has its equivalent as the L175 model. If this is true then there are two part #s.
15108-32067 up to serial no. 1304
15213-32024 from serial No. 1305
Part no.s taken from L175 parts book. Hope the above can help
regards /forums/images/graemlins/smile.gif
   / Kubota L 1500 oil filter #3
Drew, This cartridge style filter was found on very early production Kubota L1500 and L1501 tractors.
It can be upgraded to the spin on style, but you'll find that NAPA Filter # 7030 is the correct cartridge filter for your tractor!
Hope this helps! Vic B
Thankx Vic will try that one.When upgrading to a spinon oil filter.do you mean installing a oil filter housing from a L 175 or what Thankx again for the #
Drew
Vic the NAPA # 7030 is the correct # according to the WIX filter web site thankx again
Drew
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2014 Freightliner M2 106 Ambulance (A51692)
2014 Freightliner...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
Ford F-450 Utility Truck (A53473)
Ford F-450 Utility...
