KUBOTA KX 41-2
   / KUBOTA KX 41-2 #1
Skiercraig
Kubota KX 41-2
I have a Kubota KX 41-2 which I purchased last year to do mainly a section of drain (300'). When I purchased it it came with no manuals so had to get them from the dealer in Lewiston ID. Did all of the regular maintenance stuff like change the oil, filters, hydraulic fluid etc. Found that the track rollers were shot so they were replace. Everything worked except the hi speed and the glow plug relay was bad. I have not been able to get the hi speed to work. When I started checking I found that the two wires to the switch on the hi speed peddle were disconnected. I re-attached them But no hi speed. Removed the solenoid and checked it but I am not sure if the action is great enough. It does move when power is applied but after 50 years doing electronic I know some have a great deal of force and other have very little. Does anyone have any idea as to whether this should be one or the other? Also is this the same as the one next to it when it come to force?
Thanks for any help in advance:
Craig
BUSH HOG 7007 LOT NUMBER 116 (A53084)
BUSH HOG 7007 LOT...
2022 LMC H40024 LOT NUMBER 206 (A53084)
2022 LMC H40024...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2013 Ford Edge Limited AWD SUV (A51694)
2013 Ford Edge...
