Kubota KX-040-4 Relay Question
   / Kubota KX-040-4 Relay Question #1
dpauly
Bronze Member
Hertford Cty, NC
Branson 3120R
Greetings. In the Fuze Box located inside the cab (under the seat behind the lockable panel) of my 2019 KX-040 there are 10 Relays: one of which (the hardest to reach of course) is physically larger than the rest and identified as 'Power' on the box cover label. Can anyone tell me the specifics of this relay i.e. part #/ordering info; which particular circuit(s) it is part of; etc.? Unfortunately, in trying to check if this relay is working I destroyed the outer case while trying to get it out so any info that may have been visible is no longer (though the info on the other relays is very difficult to read as well.) Another question: anyone know a suitable substance to coat Relay & Fuze 'blades' with to prevent future difficult removal (if I'm correct, Dielectric Grease is actually an insulator of sorts thus would not be a good choice, imo.) Thanks in advance.
White Metal Roof Panels (A55758)
White Metal Roof...
2006 CATERPILLAR 320CL EXCAVATOR (A51406)
2006 CATERPILLAR...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
2008 DOOSAN G25 GENERATOR (A55745)
2008 DOOSAN G25...
CATERPILLAR 303.5E2 CR EXCAVATOR (A52706)
CATERPILLAR...
