Kubota, issue with safety reset
/ Kubota, issue with safety reset #1
genuine
Crownsville, Maryland
Kubota BX-24
Kubota BX-24 with about 600 hours.
Started and ran tractor on Saturday. On Sunday it started right up and ran strong. As it was quite cold I wanted to let it run for a bit before using it. I went to get up and leave it running and when I did the safety mechanism shut off the engine. OK, no problem. Sit back down and nothing. Key turning will not start the glow plugs or start the electronics. I lifted the seat all the way up and cleared any debris. Pushed and un-pushed the buttons. Put the thing in neutral, with the brake on...all levers set into neutral positions...still nothing.
After fiddling with it I gave up for the night and tried again today. Nothing....
Does anyone have an idea for me? Thanks
/ Kubota, issue with safety reset #2
Next thing I would do is check all your fuses. I have had that happen because of a blown fuse.
If all fuses are OK, I would take the connector apart for the seat switch and check it with an ohm meter to see if it's working.
Then, if it's Ok, I would get more ideas from us on here...
/ Kubota, issue with safety reset #3
HST pedal not quite in neutral or offset by twig/debris?
/ Kubota, issue with safety reset #4
I had a similar issue, PTO safety switch killed the engine (as it should), couldn't restart.
Turns out that I had to turn the ignition switch to OFF first, to reset safety switches, then it started normally.
