Kubota Hydraulic Pump mount Bolt pattern?
   / Kubota Hydraulic Pump mount Bolt pattern? #1
hill
PNW
'07 KuBoTa B7800 and Jinma 254
Does anyone know if Kubota uses a standard mounting bolt pattern for their tractor hydraulic pumps? Looking at various pumps sold in Surplus Cener I see a specification of "Mount: SAE A 2 bolt" most commonly, or "SAE B 2 bolt" for some. No doubt other mounting patterns exist.
I'm wondering about the possible advantages of changing out the OEM operations (as a separate pump not used for power steering - the tractor has two pumps) pump on my B7800 for one with a higher output, and whether such a thing is even possible given the non-Kubota pumps available.
So, I'm a power junkie....
   / Kubota Hydraulic Pump mount Bolt pattern? #2
Most of the Japanese manufacturers use a standard 2 bolt flange, 1 in 5 shaft taper and round ports with 4 bolts at 45 degrees from flat or perpendicular. They use a banjo like fitting on the two ports with the 4 bolts and an oring.
Kubota used SAE style pumps on their larger M series tractors but then adapted them to British Standard pipe fittings (sort of a step backwards for USA tractors) but the predominant pump used is the Japanese standard as above.
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
2010 Ford F350 Super Duty, Super Cab, CM Flatbed (A52384)
2010 Ford F350...
2019 Ford F-550 Service Truck, VIN # 1FDUF5HY1KEF71327 (A51572)
2019 Ford F-550...
