Kubota hydostatic leak
   / Kubota hydostatic leak #1
Jesse
Hello,
I just purchased a 1981 Kubota B6100HST with hydrostatic transmission. In the general area of the mid pto shaft, I am getting an approx 1 drip per second leak. I am not knowledgeable on this tractor. Does anyone have any idea of what the cause of the leak might be??? Also wonder if the repair is something I can tackle or must the dealer take care of it.
Thanks a ton for any reponses!
Jesse
   / Kubota hydostatic leak #2
I believe the mid pto shaft is actually a seperate casting with a spur gear inside just like a PTO on a truck. If I remember correctly, 4 bolts and it comes off (be sure to drain the oil first). There will be a seal on the inside end of the shaft that presses into the housing. Time for a new one. You might have to replace the shaft if it is worn badly from the seal friction. I don't think you can get a wear sleeve for it.
2010 Chevrolet Equinox SUV (A51694)
2010 Chevrolet...
CFG Industrial QK20R (A50121)
CFG Industrial...
Work Saver 3 pt Post Hole Digger (A50515)
Work Saver 3 pt...
2013 AMSIG S/A Solar Towable Message Board (A50322)
2013 AMSIG S/A...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
Bush Hog Mod. 300 - 14 3 pt Blade (A50514)
Bush Hog Mod. 300...
