Kubota hose diameter question, ready to order.
   / Kubota hose diameter question, ready to order. #1
Piston
Elite Member
New England
Kubota L4610 Hitachi UH083LC
I am trying to install a 4 spool valve on my kubota L4610. I measured out the hose lengths and want to order them on discount hydraulic hose.com. The only problem is, I forgot to check what SIZE hose I need! I won't be around the tractor for the next 2 weeks and will wait to order if I have to, but if someone could tell me what size hose I need, that would be awesome :thumbsup:
If it helps, the ports for the valve are all SAE #8 except the PB port which is SAE#10.
I assume it's the same size hose as other similar sized L series Kubotas. (40-46hp)
The only hose diameter I snapped a picture of, was my WR Long 3rd function solenoid valve hose, which is 3/8" but that seems small for the rest of them?
   / Kubota hose diameter question, ready to order. #2
Check you data, here is the specs. All ports are 8 except the OUT port, and it is a 10.
Do you realize the factory relief on your new valve is set at 2000. Install a gage and reset it to equal the FEL PRV.
Specifications for Y valves
Flow 12 GPM (nominal) to 16 GPM maximum
Pressure 3000 PSI maximum
Adjustable relief 1500-3000, factory set at 2000
Open Center with Power Beyond
Inlet and Power Beyond Ports SAE 8
Outlet Port SAE 10
Work Ports SAE 8
I've looked at the specs but get confused. My question is what size hose do I need?
:thumbsup:
   / Kubota hose diameter question, ready to order. #4
1/2 in hose
The OUT hose will have a SAE10 fitting on a 1/2 in hose, and what are you going to do with the end of the OUT hose, couple it to another return hose.
1/2 in hose
Thank you :thumbsup::thumbsup::thumbsup:
That's exactly what I was looking for. :D
I will tee the OUT hose into another return hose, I just don't know which one, or where, or how to do that yet?
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A53473)
LIKE NEW 2023...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A53421)
2017 Toro Z-Master...
2007 FREIGHTLINER BUSINESS CLASS M2 T/A DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2015 Ford F-350 Utility Flatbed Truck (A51692)
2015 Ford F-350...
SET OF (4) BRAND NEW CHAINS AND BINDERS (A53843)
SET OF (4) BRAND...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
