Kubota Grass/leaf catcher - anybody have one?
   / Kubota Grass/leaf catcher - anybody have one? #1
rww_94
Western PA
7500 HST - Kubota
Any one have this attachment? I'm considering this or a rear pull behind cart for leaves/grass on my 7500. I have TONS of leaves and could really use that grass clippings as mulch in my garden.
Please advise if you can. - and thanks!!!!
   / Kubota Grass/leaf catcher - anybody have one? #2
I have one and love it. The capacity is way too small though and you end up spending a lot of time going back and forth to the dumping area. Unfortunately, with all my hills and trees I thought the pull behind one would have been more trouble than it was worth. Also, in case you don't know, it's a lot different than the one for the BX. The only picture I saw before I bought my rig was the BX one which runs off the rear PTO. On the B7500 the blower runs off of one of the mower heads. I doubt if one is better than the other, but they are different. Let me know if you'd like me to take some pictures of my setup. I will be replaceing my mower blades tomorrow anyways and would be happy to do it. /forums/images/graemlins/smile.gif
Jeff
   / Kubota Grass/leaf catcher - anybody have one? #3
RWW,
I'm not familiar with the Kubota model, but I do have 2 JD grasscatchers - the 10cuft 3-bag 'Manual' model and the 13cuft hydraulic Dump Bagger for a JD4100.
I use them to pick up grass from mowing, and to pick up leaves in the fall. Got LOTS of trees around here, and the leave fall is REALLY heavy. Using stove pipe from the local hardware store, I fabricated a vacumn 'head'. It works pretty well - will even pick up wet leaves in a pile.
Both Units ride on the 3pt, and are powered by a little Honda 5.5HP vacumn engine. The Vacumn engine works great, really picks up the leaves and grass. I'd have preferred that the vacumn be PTO powered, but that would have increased the cost significantly. (The little Honda engines can be had pretty inexpensively in OEM quantities.) Ahh, next project ...:)
The Hydraulic Dumper beats the manual one hands down, of course. The manual one functioned well, but having to get off the tractor and wrestle the 3 bags off and dump them is a lot of work. The Hyd Unit connects to the FEL control valve, and so dumping is controlled by the joystick. Specifically, the process is (1) back up to where you want to dump, (2) lower the 3pt to set the unit on the ground, (3) Dump the hopper using the joystick.
I bring this up because the unit would probably work with your tractor. AND the color won't even clash! /forums/images/graemlins/cool.gif The hydraulic dumper is black.
The area you'd have to research is getting a mower boot that connects to the vacumn hose. I believe the hose is a 7" Diameter.
Let me know if I can give you any other info.
Caretaker
2019 Bobcat T590 (A50123)
2019 Bobcat T590...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A51692)
2004 Pierce Tilt...
We do NOT accept credit cards as payment. (A50123)
We do NOT accept...
2011 John Deere 5075M 75HP 4WD Loader Utility Tractor (A52377)
2011 John Deere...
2018 Ford F-250 4x4 Crew Cab Gooseneck Service Truck (A51692)
2018 Ford F-250...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
