Kubota GR2110 riding lawn mower review
   / Kubota GR2110 riding lawn mower review #1
Maineuropa
Lyman, ME
Deere 955, Kubota GR 2110, Kubota 4200
I picked up one of these second hand with the 54" mower about 8 years ago; previous owner couldn't be bothered to change the two fuel filters, ruined the fuel pump. Mow approximately 10 acres frequently along with leaf clean up in the fall; now at 1240 hrs.
As an engine it really has done well, despite two gasoline errors. Change the oil, pump out the fuel, refill, off you go.
The mower part has mixed scores for me. The mowing is ok, the ground speed is a bit slow, the grass gets cut. The anti-scalp wheels are an ongoing replacement issue. The factory mount bolt is quite loose in the bushing; a 5/16" 3" bolt fits better. I am on my 3rd set of wheels/bolts.
The leaf vacuum/blower system is just there to piss you off. I cannot tell you how many times it has clogged on me. Any scintilla of dampness and the unit clogs. The process of emptying all clog points is tedious and if you are really lucky the blower drive belt slips down and you start over re-attaching the leaf blower unit. It does a good vacuum of the lawn when it works.
Another issue is the transmission interrupter set up. This is a cable set up that runs from the front steering fork(one each opposite side) to the rear transmission where it interrupts the rear wheel drive so you do not grind the lawn/driveway/etc. with you rear wheel whenever you make a sharp turn. Nice concept, except the cable breaks frequently(I have replaced both sides).
The last repair issue has been the little rachet that locks the park brake. The idea there is that you step on the park brake, then the rachet, release the rachet, then the park brake. If you break this operational sequence, then, over time, the little teeth on the rachet get worn down until it no longer works. Very tiny hands installed the rachet; it is an interesting replacement wrenching experience.
That’s about all. I would give this unit 7 out of 10 stars. It has run reasonably well for more than a few years.
   / Kubota GR2110 riding lawn mower review #2
Mowing speed is really determined by the blade tip speed not so much HP, to a point. So the slow mowing speed your talking about is usualy caused by a low blade tip speed. Unfortunately that spec is very hard to find on most mowers.
I had a craftsman gt5000 that the blade tip speed was so damn slow idk how the previous owner put 600hrs on it and didnt get tired of its poor performance.
The biggest clogging issue for me was dampness and volume of grass being cut ( which was partly a function of ground speed). Many times the tractor rpm would work better at a slower speed but only at low volume and dry conditions. A combo of grass and leaves always clogged less than just leaves. I have often wondered if no stick PAM or WD40 would help ‘grease’ the chute and cause less clogging.
2000 Isuzu NPR-HD Landscape Truck, VIN # 4KLC4B1R9YJ802689 (A51572)
2000 Isuzu NPR-HD...
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
2009 Pontiac G6 Sedan (A51694)
2009 Pontiac G6...
Spartan Pierce Foam Pumper Training Fire Truck (A51692)
Spartan Pierce...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
