Kubota GR2100 mower deck/PTO
   / Kubota GR2100 mower deck/PTO #1
mpt1123
Hello:
I'm having problems with the mower deck on my kubota GR2100. It started with the mower engaging/disengaging while mowing. Since I've had the tractor for 11 years I figured it was just an adjustment. I made the adjustment and the mower engages but it doesn't seem to have the power it used to have. It seems to bog down a bit and I'm seeing a little more grass clumping than usual. It seems that the PTO is just not transferring all of the power to the mower deck. Is it possible this is a result of some clutch wear in the transaxle?
Thanks.
I'm thinking it may be a clutch problem. The RPM's on the mower deck go up and down while I'm mowing, almost like something is slipping. I'll have to tear it down to take a look at the clutch pack.
   / Kubota GR2100 mower deck/PTO #4
PTO clutch failing. There are several TSB's in reference to the GR2100 transmissions, might be worth asking the dealer to pull those TSB's for you.
Modine Shop Heater (A51573)
Modine Shop Heater...
2017 John Deere 9620R Scraper Special Tractor (A53342)
2017 John Deere...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
LMC G500-500A LOT NUMBER 233 (A53084)
LMC G500-500A LOT...
2023 John Deere HD40F Draper Head (A53342)
2023 John Deere...
City of Buckhannon - 2014 Ford Fusion SE (A52384)
City of Buckhannon...
