Kubota GR 2100 or 2110 Positive Reviews?
   / Kubota GR 2100 or 2110 Positive Reviews? #1
Dillier23
Illinois
Case IH, Deere, Kubota, Yanmar
Hello,
I've come across a 2005 GR 2100 Kubota diesel with 300 hours (perfect condition) on it for around $3,000. I've read online until I'm blue in the face about all the negative experiences some owners have had, but I still find it hard to believe that the Glide Steer and/or transmission problems are as bad as they seem online.
Are there owners or friends of owners out there that have had positive experiences with the GR 2100 or 2110 models?
   / Kubota GR 2100 or 2110 Positive Reviews? #2
I have a 2009 year GR2120 that I am very pleased with. Use it for mowing and snow blowing. Sorry, no experience with the GRxx00 or GRxx10 series. Philip.
   / Kubota GR 2100 or 2110 Positive Reviews? #3
As a dealer, I'd have a hard time recommending one that has not had the transmission rebuilt. Its a great little tractor, but the failure rate of the 00-series is way above average.
   / Kubota GR 2100 or 2110 Positive Reviews? #5
I have a GR2100and have no problems except for one glide stear cable. It has seen a lot of hard use and give me good service. I guess there are good ones and bad ones. Maybe I've been lucky.
Roy G
   / Kubota GR 2100 or 2110 Positive Reviews? #6
Roy G
That's great.How about some specifics like # of hours and if purchased new or used.What's the serial number? Thanks.
   / Kubota GR 2100 or 2110 Positive Reviews? #7
I bought it new. It has 376 hours on it now. Ran it for two hrs yesterday helping a neighbor. Runs good with no problems.
Don't know s/n it out in the barn. When i checked, it was built after the problems were corrected.
Roy G
   / Kubota GR 2100 or 2110 Positive Reviews? #8
Roy G
OK,that explains why you haven't had big problems.
   / Kubota GR 2100 or 2110 Positive Reviews? #9
Unless the tranny has been upgraded,forget it. I had an '07 that tranny started making noises (I can't remember hours now,I think it was over 500,I do have threads here on it). If tranny craps out,you're looking at close to $3k or more to replace. I'd keep an eye out for a GR 2120 -they don't have the cables for the glide steer either.I bought mine in spring of '07,so it could've been an '06,not sure. The serial # I think was 15369......
   / Kubota GR 2100 or 2110 Positive Reviews? #10
Yep,early model untouched maybe a grand if it's low hours.I wrote down the serial number upgrade from bushings to bearings at 12588 and the pto upgrade at 11590.Mine is serial 11880 and the pto parts were changed when they did the free overhaul,incl larger charge pump.Stronger now at 400 hrs than when new. I think all the 10 series had the upgrades on the trans and redesigned bracket mounts on the glidesteer cables which improved reliability and longevity.
I wonder how the axle clutches will hold up over time.Quick backup turns and stabbing the hydro quickly back and forth will likely shorten the lifespan.It's tempting to cowboy the system,but I don't ram it around and give the clutches time to do there thing.
1997 FORD SINGLE AXLE DUMP TRUCK (A43004)
1997 FORD SINGLE...
2014 FREIGHTLINER M2 TANDEM AXLE FLATBED WITH MOFFETT HOOK UP (A43004)
2014 FREIGHTLINER...
2012 KENWORTH T800 MID-ROOF SLEEPER (A45333)
2012 KENWORTH T800...
2007 CAT 308C Excavator (A42203)
2007 CAT 308C...
2022 Deere 26G (A44501)
2022 Deere 26G...
2008 SJ PETROLEUM XJ400 WORK OVER RIG (A45333)
2008 SJ PETROLEUM...
