BruceWard
Platinum Member
I am considering one of these to use as a standby generator for my home with the added convenience of being able to put it in the back of my truck and use it in the field. They weigh 500+ pounds so the B21 would be used to load and unload.
Kubota's specs are online at Kubota Engine America - Compact Diesel Engines for the GL11000 and Kubota Engine America - Compact Diesel Engines for the GL7000.
They run at 3600 rpm which reduces their efficiency.
I expect the generator would run less than 6 hours a month with an occasional extended run of up to 10 days. I want to use diesel fuel due to its longer life span compared to gas. LP is not an option. I would likely sell all remaining fuel to a local operator and restock once a year. These generators have small tanks but I can easily store a larger quantity of diesel and gravity feed it to the generator.
Can anyone suggest similar but more efficient or cost efficient alternatives.
Thanks in advance for your advice.
