Kubota GL-5240 HSTC-3 Will not move Help Please
   / Kubota GL-5240 HSTC-3 Will not move Help Please #1
bitseeker
Mount Shasta, California
GL5240
Kubota GL-5240 HSTC-3 Will not move Help Please - FIXED - THANK YOU!
I had tilted the seat up to get stored wrenches and the stationary seat belt half fell under the seat, inhibiting the occupancy switch. THANKS for the tip.
Yesterday, I moved the GL-5240 HSTC-3 forward approximately 20 feet in the long narrow building it stays in to get at and loan a piece of equipment to a neighbor. There was no issue, except I do not like to start and stop the engine before everything warms up.
This morning, I went to move it back to remove the loader and install the snow blower because a fair-sized storm is forecast for later this week. The engine stalled with any attempt to move it forward or backward. It acts as though the brakes are stuck on hard.
The building is dry and has not gone below freezing, so temperature-frozen brakes are unlikely.
The following are tests I have made to find the cause with no insight on my part. Please suggest what may be the cause and what I can do to test and fix.
- The engine speed is fully controllable by the Hand Throttle Lever
- Using either the Foot Throttle or the Cruise Control Lever to cause motion cause the engine to attempt to stall. Reducing throttle position reduces apparent engine load.
- The problem happens in every HST mode, MANUAL, STALL GUARD, & AUTO H-DS/STALL GUARD)
- The problem happens in every Range Gear Shift Lever position (L-M-H)
- With very high (2,500 RPM) engine speed and very gentle rear Foor Throttle does cause rearward motion, yet it would not be practical to move the tractor even 5 feet.
- All the other hydraulics work fine. (Loader, Rear Flail Mower up/down, and Mower PTO).
- I operated the brakes independently and together with maximum force multiple times with no change.
- The engine stall response happens with the transmission in Neutral and the Clutch pedal depressed. This makes me think that it is a logical or electrical problem, and I think it excludes stuck brakes and mechanical failure like jammed gears. The fact that it did move a few inches with the high throttle setting tends to confirm this.
Any ideas will be GREATLY appreciated.
   / Kubota GL-5240 HSTC-3 Will not move Help Please #2
Not familiar with this machine, but I'll hazard a guess. Would help if you posted year, # of hours, last clutch adjustment, etc.
My guess is the clutch disc is not doing it's job. It could be stuck or worn to nothing, again depending on use/hours, and how long it's sat since last use.
Give details asked for above....
   / Kubota GL-5240 HSTC-3 Will not move Help Please #3
Sounds like a safety switch of some sort to me.Possibly under the seat but I don't know.Is there anything showing on the dash panel?Good luck.
It is a 2010 year. Has only ~ 250 hours. No clutch adjustment done ever. It sat approximately 18 hours since it worked fine.
I'll look in the operator manual regarding clutch adjustment. Also seat switch status as another suggested.
@kcender,
Thanks so much. I had lifted the seat to get wrenches and when I lowered it, trapped one end of the seat belt under the seat. With that removed, everything works fine.
Excellent call. I really appreciate your advice.
   / Kubota GL-5240 HSTC-3 Will not move Help Please #6
Great! I knew it was a blown clutch.:duh:
   / Kubota GL-5240 HSTC-3 Will not move Help Please #7
What is this "clutch" you speak of on an HST tractor? ;):D:D
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A53426)
2007 POWERSCREEN...
2013 Ford F-550 Passenger Bus (A51692)
2013 Ford F-550...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51692)
2006 iDrive...
2011 CHEVROLET EXPRESS SERVICE VAN (A51406)
2011 CHEVROLET...
2014 Kubota B2320 (A50123)
2014 Kubota B2320...
