Kubota G2160
   / Kubota G2160 #1
Gitrdone2dayt
KubotaG2160
The mower is a Kubota G2160 2001 runs great when you first start but after a while if you stop for anything and then try to engage the mower it kills the machine I feel like it is something electric I can hear the stop solenoid engage then release after a few minutes when mower is dead please help
   / Kubota G2160 #2
I would look closely at the seat safety switch given your symptoms. Try bypassing the seat switch as a test.
   / Kubota G2160
Thanks for the heads up when I started to remove it a wire popped out someone had already bypassed it partially not sure how they did it when I unplug the wire that was in there shot out I replaced the switch and all is back to normal thanks so much saved Momma's mower heck its only 21 years old still a lot of life there
   / Kubota G2160 #4
Glad you got it going.
   / Kubota G2160 #5
"Momma's mower"...that's a good thing (y) on quick fix. :)
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
TEST BID LOT (A50775)
2016 CATERPILLAR CT660 TRI AXLE DUMP TRUCK (A51222)
2016 CATERPILLAR...
Kenco PH9000 Self-Leveling Pipe Hook - 9,000 LB Capacity, 8FT Max Pipe Length (A51039)
Kenco PH9000...
TOYOTA 8FGCU30 FORKLIFT (A50854)
TOYOTA 8FGCU30...
2005 International 4300 Heil Dump Truck (A50323)
2005 International...
