Well let's see. I have an
L2800 4WD, HST with TnT, and the Delta Quick hitch. I have a 60" Bush Hog finish mower that I cut about 3 acres of grass with and one 25 degree hill. The BH rear finish mower is ground contact equipment with about 600 pounds resting on four narrow tires. This causes unacceptable ruts in wet areas and rainy times which is often. My 20 year old JD 285 is about to croak a natural death and I need a grass cutter with a suspended deck and at a minimum 2WD with traction lock.
The JD has been a fine machine, but I will never have an electric clutch machine again and that is all JD offers until you get into the X700 line up and that is $10K plus and not acceptable.
So I am off looking at all wheel drive models such as the Kubota GR series.
