Kubota g2160 power steering.
   / Kubota g2160 power steering. #1
Botle
USA
Hi, I have a Kubota G2160 and the power steering has stopped working. I have stripped most of it down and discovered the control box has an LED flashing 1 long and 3 short. I asume this is a fault code.
Does anyone know what 1 long and 3 short flashes mean, it does it from when the ignition is switched on and with the engine running and won't stop untill switched off?
I have tested the motor and it works fine. There is a sensor but I can't remove it its stuck in the steering coloumn.
I have a parts manual and the whole steering column has to be replaced, individual parts aren't available. I have a feeling this is going to be expensive.
Has anyone had this before?
Thanks,
   / Kubota g2160 power steering. #2
An internet search of your problem reveals that there is a fairly simple procedure to reset the error and recalibrate your steering. Your Kubota dealer should be able to help you. It's probably a minor problem. I don't know the procedure, but found someone else who had the 13 code and said their dealer got them going with a simple procedure.
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
Case-IH 370 Steiger (A50120)
Case-IH 370...
New Land Hero Mini Excavator (A53002)
New Land Hero Mini...
John Deere 4020 (A50120)
John Deere 4020...
2009 Volkswagen Jetta Passenger Car (A51694)
2009 Volkswagen...
2012 John Deere 7280R MFWD Tractor (A52748)
2012 John Deere...
