Kubota Front Axle Seal
   / Kubota Front Axle Seal #1
dentonsisk
Lyncyburg, Virginia
Kubota M4700, Ford 8N(2), Farmall Cub(2)
I noticed a leak just starting today on my 1997 M4700 4WD. It is coming from the front axle bevel. I have read somewhere that this is a common leak and was wondering if anyone had replaced or had a link for parts blowup. Search came up with limited help.
apppreciated
denton
   / Kubota Front Axle Seal #2
Replaced the seals on my L2350, If your good with tools it basicly straight forward, remove the wheel all the bolts around where hub comes out then remove bolts on main axle housing slide off remove snap ring and the unit will slide apart where seal is and replace with new one and reverse order to assemble
2012 BMW 328i Coupe (A51694)
2012 BMW 328i...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
2014 Nissan Rogue Select SUV (A51694)
2014 Nissan Rogue...
New/Unused 7ft Workbench (A51573)
New/Unused 7ft...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
