kubota filter
   / kubota filter #1
deuce1972
Kentucky
I have a approx 1980 B7100 is there a filter for the hydraulics and if so where my hydraulics will not work at all when the tractor has warmed up i would appreciate all the help
Thanks Troy
   / kubota filter
where is that screen located at and what all i s involved in taking it out
Thanks Troy
   / kubota filter #4
If you follow the big suction line from the pump to the rear, on the right side below your foot there is a large headed bolt mounting the tube to the case. This is the strainer. You will lose your fluid when you remove this so be prepared.
2019 Ford F-350 4x4 Flatbed Truck, VIN # 1FDRF3HT7KDA15849 (A51573)
2019 Ford F-350...
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
(4) 55 GALLON POLY DRUMS (A51248)
(4) 55 GALLON POLY...
2017 Ram 5500 Chassis Crew Cab Reading Service Truck (A52377)
2017 Ram 5500...
UNUSED CFG MX15RX EXCAVATOR (A51247)
UNUSED CFG MX15RX...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
