I have new to me Kubota f3060 that decided not to start. When I turn the key to the start postion it fires up but as soon as I release the key to the run position it instantly cuts out. I replaced the ignition switch but the same thing is happening. If I unplug the fuel stop solenoid the engine will crank but will not fire. Is there a key switch timer between the ignition switch and fuel stop solenoid? Is the fuel stop solenoid wired to the starter that is shutting it down? Is there any kind of fuse or relay in between the ignition switch and fuel stop solenoid? The resistance of the 3 wire fuel solenoid are red/white-230 ohms, red/black-230 ohms, white/black-0.5 ohms. I also don't see a fuse block anywhere. I only see a group of three fuses on the right side of the frame. Any help would be greatly appreciated. I don't have an operators/service manual unfortunately.
