tnbigal
Posted earlier on thread that I thought I had this issue figured out:
http://www.tractorbynet.com/forums/kubota-owning-operating/255926-kubota-electrical-problem.html
Symptoms: Getting nothing when key is turned. Lights and flashers won't even turn on. Battery is new, good, and charged. All fuses have been checked and are good. I replaced the ignition switch thinking that was the issue. Problem is intermittent. Once it comes on and starts, it will run fine. Used it all day one day, and then the next day, nothing.
I think I have it narrowed down to one of the relays behind the dash:
110 Relay Glow T1060-33710
020 Unit Flasher 3F240-75430
090 Timer OPC TD060-30500
010 Relay Starter T1060-33720
I guess there could be an issue with a switch or a sensor that feeds these relays. Just hard for me to understand which of the above would keep the lights/flashers from even coming on. The Electrical Manual shows the relays, location, and part number, but doesn't give an explanation on the relay function or what each wire on the relay represents.
A couple of the relays above that I suspect are the issue cost 75 each. I've already replaced the 50 dollar ignition switch and that wasn't the issue. I just don't want to keep throwing money at it.
