V65ozzie
Bronze Member
I have a piece of equipment(Terramite t7) with a D1105 engine. It's been running rough for a few days, and checking the service records shows me it overdue for filters. I replaced both(it has a small plastic trash filter near the fuel tank and the cartridge filter bolted to the motor) Fired it up and all seemed good. Driving it to it's parking spot I noticed a tire was low, pulled up the the shop, shut it down, filled the tire, now it's a no start.
Things I've done:
1)Checked for fuel flow from electric pump, good flow, up to the injection pump, and running back out the return
2) disconnected lines to injectors, and cranked, no fuel evident.
3) pulled shut off solenoid, unsure of how to test, it has a 2 prong connector and a secondary ground bolted to the body. I checked the source wires. key on, I have power to one wire in the connector, the other is a ground. With key off I still show a ground, but no power.
I connected a power probe to the corresponding connectors on the solenoid and juiced it. The pin does not move in and out. Should pin retract in run mode? If I push it in with my finger, it will stay in with power applied, but not retract on it's own. removing power returns the pin to the out position.
Connected power to the negative(I believe) terminal and grounded chassis, pin moved rapidly in and out.
I believe the pressure pump has a manual bypass lever(next to throttle cable connection) I moved this to all positions while cranking, still no fuel.
At this point I'm pretty much lost, diesels are really not my thing. But, I'm learning........
Anyone have any tips on testing solenoids, anecdotal experiences, suggestions?
Thanks in advance
Things I've done:
Thanks in advance
