Kubota BX2750 snowblower
   / Kubota BX2750 snowblower #1
Rmbtoys
Hamburg pa
Kubota bx2350
Can someone please give me directions on how to remove the fan impeller on my bx2750 snowblower or give me a video link.
Rich
   / Kubota BX2750 snowblower #2
You'll need to remove the chain/gear assembly from the back. Take everything off the front (auger bearings and gear box support) and pull the assembly out the front.
It's fairly straight forward.
Depending on the age, you might want to consider replacing the bearing behind the fan while you have it torn down this far.
In a similar style blower, I also added grease fittings to the fan. Helps to ensure the fan is free on the shaft should it encounter an obstacle requiring the shear bolt to break and spin freely.
Maybe this link will help visualize the parts. Kubota BX275� (5�" FRONT SNOWBLOWER) Parts Diagrams
WICHITA TANK 500BBL WHEELED FRAC TANK (A45333)
WICHITA TANK...
2021 ATLAS COPCO XAS 110 COMPRESSOR (A45333)
2021 ATLAS COPCO...
GAS LEAK DETECTION DEVICE (A45333)
GAS LEAK DETECTION...
PALLET OF PIPE ROLLERS (A45333)
PALLET OF PIPE...
PALLET OF PIPE WRENCHES (A45333)
PALLET OF PIPE...
Aqua Sculpt Reviews 2025: The Latest in Body Contouring
Aqua Sculpt...
