Kubota BX2670 tractor
   / Kubota BX2670 tractor #1
arlingevers
St. Henry
2014 Kubota BX2670 and Kubota L4610
I own a Kubota BX2670 with a mid mount deck. I want to covert the deck to a front deck using the sub frame that they use for the front snow blower. The reason I want to do this is first of all, it is much easier to install/remove the deck and I mulch my lawn. if the deck is on the front you do not pack down the grass first before you mow it. You may ask why do I not just buy a front deck mower. Well, as you well know, it is very handy to have a tractor that you can use with a loader etc. Has anyone tired this on a Kubota BX tractor?
   / Kubota BX2670 tractor #2
I have never heard of anyone doing this but sounds feasible. Good luck on your venture! I'd like to see it if you do ever do this. :thumbsup:
   / Kubota BX2670 tractor #3
You might want to check mower and see if turns CW or CC then check and see if it match engine.
I will post pictures when completed
as far as how the PTO runs I am going to use the mm deck and just move it forward and use the PTO ext that they use for the front snow blower so it will run the same way. I also plan to add dolly wheels to the front
Thanks for your comments!
   / Kubota BX2670 tractor #5
Sounds intriguing. Have you checked if the snowblower PTO shaft will hook up to the deck and is the right length? I would think you'd have to fab up your mounting hardware first, then measure for the PTO shaft. Keep us posted.
A local dealer has the frame and pto extension for the snow blower coming in shortly for someone else. He said I can look it over and see if it will work. I looked at the video on you tube installing the snow blower and with some work to the front deck, it may work I will post if I get it working (will be my brother and myself winter project. Thanks for your interest
2014 MANAC TRAILER USA END DUMP TRAILER (A45046)
2014 MANAC TRAILER...
Frontier Hay Spear (A44502)
Frontier Hay Spear...
Case IH 5140 (A44501)
Land Pride PT 10' Mower (A44502)
Land Pride PT 10'...
Exide SCR200 36V Industrial Forklift Battery Charger (A44571)
Exide SCR200 36V...
2015 KENWORTH T680 SLEEPER (A43004)
2015 KENWORTH T680...
