kubota bx2660 loosing power
   / kubota bx2660 loosing power #1
jojo57
hernando, ms
kubota bx 2660
i have a kubota bx 2660 4 wheel drive.... the front wheels stop pulling when under a load... when i first start out it works then it just stops and the back wheels start spinning... any suggestions greatly appreciated
   / kubota bx2660 loosing power #2
So it seems like the front wheels aren't pulling, as in the 4x4 isn't working? Or it seems like it losing power and the engine isn't pulling like it should?
   / kubota bx2660 loosing power #3
Are you sure the front not pulling? It could be the differential kicking in and making the less resistance wheel to free wheel on front. Have you tried shifting out and back in the 4wd? Have you checked the front wheel driveshaft to make sure its ok? To do this I'd shift into 2wd and lift the front with FEL. try rotating the shaft for play.
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
2009 International Frazer Bilt X-514 Ambulance (A52377)
2009 International...
New/Unused 7ft Stainless Steel Work Bench with 10 Drawers (A51573)
New/Unused 7ft...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2012 MAC MFG 53' WALKING FLOOR REFUSE TRAILER (A53426)
2012 MAC MFG 53'...
