Kubota BX2660 3-point hitch removal
   / Kubota BX2660 3-point hitch removal #1
burg
West Bend Wisconsin
Kubota BX2660
I'm having trouble with a Kubota BX2660 3-point hitch removal. Anyone have a good description of how to remove?
   / Kubota BX2660 3-point hitch removal #2
Burg,
If it's like mine on my2370, it's a little tricky. I'm sure folks here have all the correct terminology but I'll do my best to describe:
The lower part of the hitch is attached to a rod that runs across the tractor frame. Flip up the large plate that is attached to the rod and remove the cotter pin from the silver pin. Knock or pull the silver pin out, this will allow you to lift that plate off of the rod.
Here's the not so obvious part: at the ends of the rod there are two collars, one of each side, they look like bushings, but they actually pull right out ( toward the center of the tractor) when you pull those collars out of the tractor frame you can now maneuver the rod out of the frame. Pictures would help I'm sure, but I'm REALLY comfy here on the sofa watching the game with a cold adult beverage.
Hope it kinda helps
Cheers,
BN
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2019 JOHN DEERE 5090M LOT NUMBER 91 (A53084)
2019 JOHN DEERE...
2013 Club Car Carryall 252 Electric Utility Cart (A51691)
2013 Club Car...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
2003 Polaris Sportsman 700 Twin (A51573)
2003 Polaris...
2010 International 4300 2,000 Gallon Water Truck (A52377)
2010 International...
